Inventor Forum
Detail View Annotation
3 REPLIES 3
SteveFrey
559 Views, 3 Replies
What setting controls the line thickness attached to the arrows in the attached Detail View?
Steve Frey
Inventor 2021
Windows 10 Professional 64-bit
HP ZBook 17 G6
Processor: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
Memory: 80 GB
NVIDIA Quadro RTX5000
3D Connexion SpaceMouse Wireless
3 REPLIES 3
coreyparks
in reply to: SteveFrey
See the attached pic from the style editor dialog box.
Please mark this response "Accept as solution" if it answers your question.
Corey Parks
SteveFrey
in reply to: coreyparks
Hey, thanks.  I wish they would make it easier to determine what controls what.  I wonder if anyone has a chart with the explanation of each setting?
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
harco
The Object defaults style will point you in the right direction if you are looking for some other control settings.
http://docs.autodesk.com/INVPRO/2010/ENU/Autodesk%20Inventor%202010%20Help/index.html?url=WS1a919382...
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0285-Work_Env285/0292-Styles_a29...
Set the default style and layer for individual drawing objects
The default style and layer for a type of drawing objects is specified in the Object Defaults style.
  1. Select Manage tab Styles and Standards panel Styles Editor.
  2. In the Style and Standard Editor dialog box, expand the Object Defaults node in the browser, and select the Object Defaults style.
  3. In the Object Defaults window, set styles and layers for individual object types. Click a current Object Style or Layer, and select a new style or layer from the list.
  4. Click Save to save the edits.
  5. Click Done to close the Style and Standard Editor.
