What setting controls the line thickness attached to the arrows in the attached Detail View?
Solved by coreyparks. Go to Solution.
See the attached pic from the style editor dialog box.
Hey, thanks. I wish they would make it easier to determine what controls what. I wonder if anyone has a chart with the explanation of each setting?
The Object defaults style will point you in the right direction if you are looking for some other control settings.
Set the default style and layer for individual drawing objects
The default style and layer for a type of drawing objects is specified in the Object Defaults style.
