Can Mechanical Desktop 2009 be installed with Inventor 2013?
Solved by jimlong50. Go to Solution.
Yes,
I have also had it running with 2014. You just need to make certain your subscription agreement entitles you to the license.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
and if you're talking MDT + Iv2014, then I'm guessing you're on Win7? or have you got MDT to work with Win8? just out of interest.
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Yes I am running Windows 7. Our subscription license supports legacy Inventor 2009 files. Do I need to install an older version of Inventor, such as 2012, to be able to install Desktop 2009?
I did not have to. I only had 2013 installed when I put it in. Now there is a special installer for Inventor 2013 and later. It is a special MDT2009 installer to do it. Otherwise it will look for an older Inventor first.
Mark,
Thank you for the information. One last question. Where can I download this installer? I have 3 stations that are running Inventor 2014 and one that is still at 2013. I looked on the Autodesk web site but couldn't find anything.
