Inventor General Discussion
Active Member
kevinzaskowski
Message 1 of 5 (128 Views)
design window
128 Views, 4 Replies
10-12-2012 04:49 AM
i am doing a presentation, but don't want the gray background.  how do i change the color?  thanks
Making a presentation of what?  Powerpoint slides of Inventor images?  Inventor assembly live on the screen?
Did you try changing color schemes?  What do you want it to look like?
You haven't so far given nearly enough information to allow anyone to help you.
*Pro
sbixler
Message 2 of 5 (126 Views)
Re: design window
10-12-2012 04:52 AM in reply to: kevinzaskowski
What version of Inventor (always provide this in your first post!)?  Have you tried Application Options > Colors tab?
Active Member
kevinzaskowski
Message 3 of 5 (122 Views)
Re: design window
10-12-2012 05:03 AM in reply to: sbixler
autodesk inventor 2012
*Pro
sbixler
Message 4 of 5 (117 Views)
Re: design window
10-12-2012 05:13 AM in reply to: kevinzaskowski
Active Member
kevinzaskowski
Message 5 of 5 (110 Views)
Re: design window
10-12-2012 05:33 AM in reply to: sbixler
Thank you.  It was under the "application option" that you described above.  Thanks!
