I have a message pop up when i am trying to save an assembly. it is:
'The current Design View Representaion is locked. Changes againstit will not be saved. If you want to keep those changes please create a new Design View Representation or unlock the current one.'
How do i do this?
In the Model Pane, under Representations, expand "Views". Is there a check mark by "MASTER"? If so double-click on "DEFAULT" (found directly under "Master"). That should unlock things for you without having to create a new representation.
