I'm pretty frustrated right now. I was working on a multibody part and had to make some changes to the reference plane I used to split the parts. This caused the referenced parts to swap breaking everything bellow the split on the design tree. I spent a few hours going through every feature and assigning the correct solid. Everything is back to normal now, however the design tree tends to break a lot. I consider myself to be pretty organized when it comes to the design tree taking care of keeping referenced features together, etc.
I ran an experiment, if I open my part and move the end of part up to about halfway through the design tree, let it rebuild and then without making any changes pull it back down, a whole bunch of features break! This had been happening in the past but I thought it might have been a coincidence. How is it possible to break the design tree without changing a thing?
I cant really share the files I'm working with so I dont expect much help, but has anyone ever had this issue?
Alan,
I am just trying to understand what you are talking about when you say your design tree broke? I assume you are talking about the browser. Can you post some images of this?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
