Chris,
Open ABC.iam in the DA.
Highlight the assembly and all parts in the upper window(drag or CTRL
select), and in the lower window, make sure that IDW is checked and hit
the "find files" button.
Let it crunch.
Now, copy/rename the ABC.iam and the part files.
Then, go into the bottom window and copy/rename all the IDW's.
action button and *all* will be copied in one shot-they have to be
renamed individually>
Once all copies/renames/relocates are done and look right, hit the save
button.
Makes sure you add the paths to the new files to the Project before you
do any of this (unless you are utilizing subfolders)
QBZ
"Chris" wrote in message
news:FAB699370371561575F21B6D17F423C4@in.WebX.maYIadrTaRb...
> Let say I have ABC.iam and ABC.idw (associated with ABC.iam).
> Then there are 3 parts: A.ipt, B.ipt, and C.ipt in the ABC.iam
> and there are 3 idw files: A.idw, B.idw, C.idw (associated with A.ipt,
> B.ipt, C.ipt respectively)
> To have a new set of dwg. I use DA
> Open DA from ABC.idw, I can copy to a new set:
> ABC.idw to ABCnew.idw
> ABC.iam to ABCnew.iam
> A.ipt to Anew.ipt
> B.ipt to Bnew.ipt
> C.ipt to Cnew.ipt.
> The question is: How to use DA to copy A.idw to Anew.idw (associated
with
> Anew.ipt) ? IV won't let me because Anew.ipt already exists in the
earlier
> DA copy.
> Any idea how to get this thing done?
> Thank you in advance for any help.
> IV 7 sp1
> Dell Workstation PWS 360
> Windows XP Pro sp1
> Pentium 4 - 3.0 GHz & 1.5GB of RAM
> NVIDIA Quadro FX 1000 - 6.14.10.4403
> 18 x 20 dual UltraSharp Monitors
