Hello everybody,
which template uses the design assistent for bolt connections? It is not the standard norm.iam.
Thanks for help
Hi.
Any *.iam template has access to Bolted Connection tool
What exactly is the problem?
in the picture you can find Schraubenverbindung2.
This is created from design accelerator. Which template is used?
I also don't understand the question. FYI, Bolted Connections are created by a Design Accelerator. The IAM file is populated with entries from the Content Centre.
