Brian:
I'm not operating over a network and I find DA to be pretty slow.
The best advise I've got, and no doubt you've cottoned on to it, is to
work at the lowest practical assembly level, i.e. open a 20 part
subassembly rather than a 500 part general assembly.
Richard
Brian Corbin wrote:
> WHat the heck is up with Design Assistant being so slow?
> Forget that the UI is a DOG and its is so hard to use etcetc its still the
> best we have for some things, but the speed is just way below anything I
> have seen, ie:
> I have a 176k .IAM file sitting on our server
> it has 313 parts total, 189 Unique. Not a huge assm in anyones book.
> We have good quaility workstations all with Quadro cards in them. We work in
> a semi-iso enviroment with 3 INV workstations. We have a direct 1gig Network
> connection to a hub plugged directly into our own dedicated INV server.
> If I open the above mentioned assem in INV it takes 49 secs to get on screen
> and be ready to edit, which is acceptable and I can live with. Yet If I open
> the same file in the same network location with DA (which only manages links
> so I would have thought has a LOT less work to do than the full INV) it take
> 4.5 minites!
> Then everytime I make a change and do a save, it does a full refresh which
> agains takes longer than is acceptable in any office enviroment?
> Is there any tricks to speeding DA up or am I stuck with it being a slow dog
> forever?
> It just seems like with the amount of work it is doing compared to INV that
> it should open the file WAYYYY faster than the full INV does?
> Brian
