Inventor General Discussion
Active Member
phoebus.biron
Message 1 of 15 (1,975 Views)
Design Assistant - Renaming Files
1975 Views, 14 Replies
11-02-2012 08:12 AM
I am using Design Assitant to rename files, but have had no luck with other referenced files.
I have followed the Procedures from AutoDesk WikiHelp.
Steps taken (summary)
1. Open Top Assembly.
2. In the top browser, I select the part and set Action -> Rename.
3. Rename File.
4. In the bottom browser, I select the file types for additional referenced files.
5. I select (highlight) all the files.
6. Click "SAVE"
When I go to open the files, to check if the changes have been made, obviously to rename works on the Top Assembly,
BUT for other additional refereced files, it doesn't.
I am doing this in a Single User Project.
Just wondering if there are other steps that need to be done to use Design Assistant properly.
Thank you.
Phoebus
Distinguished Mentor
john.retzlaff
Message 2 of 15 (1,969 Views)
Re: Design Assistant - Renaming Files
11-02-2012 08:37 AM in reply to: phoebus.biron
Can you post a screen shot of DA the way you have it setup to rename the files?
John Retzlaff
Active Member
phoebus.biron
Message 3 of 15 (1,963 Views)
11-02-2012 08:47 AM in reply to: john.retzlaff
See "Screen Shot" of DA, attached.  Hope this is what you were asking for.  Thanks for the help.
john.retzlaff
Message 4 of 15 (1,957 Views)
11-02-2012 08:57 AM in reply to: phoebus.biron
Actually what I was hoping to see was how you had the Action and Name columns setup when you do the rename.
Do you have a smaller assembly you can test with?
John Retzlaff
Active Member
phoebus.biron
Message 5 of 15 (1,944 Views)
11-02-2012 10:40 AM in reply to: john.retzlaff
Are you referring to the options that pop up when I right-click on the Action and Name columns?
See the attachment.
If not, please elaborate.
john.retzlaff
Message 6 of 15 (1,931 Views)
11-02-2012 10:51 AM in reply to: phoebus.biron
So after you have selected rename in the action, you will change the Name (this is the file name).
Then hit save, and that component will be renamed.
Is that what you are trying to do?
John Retzlaff
Active Member
phoebus.biron
Message 7 of 15 (1,925 Views)
11-02-2012 11:10 AM in reply to: john.retzlaff
Thats exactly what I am trying to do.  But I would also like the files to be reflected in all the referenced files.
john.retzlaff
Message 8 of 15 (1,917 Views)
11-02-2012 11:18 AM in reply to: phoebus.biron
So you are renaming a subassembly, and you also want to rename the components referenced by the sub?
John Retzlaff
Active Member
phoebus.biron
Message 9 of 15 (1,906 Views)
11-02-2012 11:30 AM in reply to: john.retzlaff
I would like to rename a part.  The new part (and file name) as I understand it, if renamed in DA, should be reflected in the top assembly, which the part is in.  And with DA, it can also be reflected in the referenced drawings.
john.retzlaff
Message 10 of 15 (1,902 Views)
11-02-2012 11:33 AM in reply to: phoebus.biron
So after you rename a part, then open the assembly drawing, the new part name is not showing up?
I guess I am not really understanding the problem, sorry.
John Retzlaff
