Inventor Forum
Design assistant - RENAME not good...
3 REPLIES 3
277 Views, 3 Replies
When a RENAME a .IPT file the design assistant is adding a period to the file
Example:
old name: plate01.ipt
new name: plate02.ipt (wath I want to be)
real name after saving is: plate02..ipt
How do I remove that period (.) within the desing assistant.
I'm working with R6.
Thank for the help.
3 REPLIES 3
I've heard about his, I've seen files on the network like this. Does anyone know if a bug has been logged on this? Is it easily reproducible?
And all this time I thought it was my penchant for typos... I've seen this
a few times as well. Don't know what causes it..
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"rllthomas" wrote in message
news:f14da32.0@WebX.maYIadrTaRb...
Fighting those bad memory cells here again, but if I remember right the cause is from
adding your own extension. I think if you leave the extension off it adds the extension
itself and does it right.
I suppose I should go double check, but can't for a bit.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"rllthomas" wrote in message news:f14da32.0@WebX.maYIadrTaRb...
