Inventor Forum
Design Accelorator - Cam Problem
2 REPLIES 2
CAD
183 Views, 2 Replies
Hi, I created a cam using the design accelerator and created an assembly using it, now it has come around to manufacturing it and I can't dimension the cam at all and I need to get it made.
Does anyone have any idea how how I can do this?
Many thanks
Chas
2 REPLIES 2
JDMather
in reply to: CAD
You should have the Displacement Diagram from the DA.
CAD
in reply to: JDMather
I can find the Displacement graph and have tried saving the data and when I opened the notepad pad files it was a lot of numbers that I couldnt make any sense of.I also tried to export the template and got much the same result.
Could you please explain how I can use this to get the cam made? I have little experience with cams and although I have been using inventor for a few years I am by no means an expert.
Anything you can do to help will be greatly appreciated
Best regards
Chas
