Inventor Forum
Design Accelerator problem
2 REPLIES 2
eliyae
489 Views, 2 Replies
Hi. When I want to insert an attach with the design accelerator, I can't. I've an error message 'A request sent to the content center has aborted. Verify that all the libraries are available in the content center file configuration or check the connections'. Do you know this message and how can I resolve this problem ?
2 REPLIES 2
alessandro.gasso
in reply to: eliyae
I hope you can find useful the following article, from where you can download the hot fix for the Vault Server that should fix the problem.
http://beinginventive.typepad.com/being-inventive/2011/08/content-center-elements-not-available-when...
Kind regards,
Alessandro
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
eliyae
in reply to: alessandro.gasso
Ok. The fix solve the problem. Thanks
