Inventor Forum
Design Accelerator Greyed out
7 REPLIES 7
Message 1 of 8
1564 Views, 7 Replies
Hello Autodesk,
I am using version 2014 and all the tabs under "Design" are greyed out. I am trying to use the "Insert Frame" function.
Any help is greatly appreciated.
Note: Windows 64bit. Recently upgrade from 2013.
Similar problem Here: http://forums.autodesk.com/t5/Inventor-General/Design-Accelerator-grayed-out/td-p/4372919
7 REPLIES 7
Message 2 of 8
JDMather
Have you installed Service Pack1?
Message 3 of 8
CCarreiras
Hi!
I think you're in "Express Mode". Check if you have the "Load Full" Icon ( main Ribbon Right) and click it to pass for full mode and then you will have all the tools available..
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 4 of 8
in reply to: JDMather
Hello JD, thanks for the quick response. No I have not installed SP1 yet. My supervisor's computer does not have it installed either but he doesn't have the greyed out design tabs. This is a new computer but I dont think there are any licensing issues.
Message 5 of 8
in reply to: CCarreiras
Thank you Carlos.
So I went to application options and UNchecked "Enable Express Mode."
I still cannot use "Insert Frame"
Message 6 of 8
CCarreiras
Hi!
Can you post a printscreen of the assembly enviroment? (Assemble Tab)
CCarreiras
Message 7 of 8
The frames were inserted in 2013 version on an older computer.
Message 8 of 8
Update: Installing SP1 fixed my problems. I orignally had mold assembly and mold layout as part of the main ribbon before and those dissapeared with my troubles. I'm not sure what the original problem really was.
