Hello Autodesk,
I am using version 2014 and all the tabs under "Design" are greyed out. I am trying to use the "Insert Frame" function.
Any help is greatly appreciated.
Note: Windows 64bit. Recently upgrade from 2013.
Similar problem Here: http://forums.autodesk.com/t5/Inventor-General/Design-Accelerator-grayed-out/td-p/4372919
Solved by JDMather. Go to Solution.
Have you installed Service Pack1?
Hello JD, thanks for the quick response. No I have not installed SP1 yet. My supervisor's computer does not have it installed either but he doesn't have the greyed out design tabs. This is a new computer but I dont think there are any licensing issues.
Thank you Carlos.
So I went to application options and UNchecked "Enable Express Mode."
I still cannot use "Insert Frame"
Update: Installing SP1 fixed my problems. I orignally had mold assembly and mold layout as part of the main ribbon before and those dissapeared with my troubles. I'm not sure what the original problem really was.
