I am having a problem with the design accelerator in 2014. The tab is there, but I cannot click any of the buttons to actually insert a frame or design some gears. They are all grayed out. The design Accelerator appears to be loaded in the add-ins screen. I am running Win 7 64 bit. Thanks for any assistance.
Are you in part or assembly mode?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I am in the assembly mode. I reopened the assembly and the design stuff showed up this time. Any ideas why it was blocked?
Only thing I can think of is if you were in the assembly, but had a part open for editing. DA tools won't work in part environment. Other than that.... not sure why.
Chris Benner
Without seeing a screen shot I couldn't say for sure, but if it happens again, check to see if the end of the ribbon has a button titled Load Full. If it does, this means that you opened an assembly with more than 500 unique occurrences (default setting), and it opened in a lightweight mode called Express in which some commands are not available.
To enable all commands, click Load Full.
Cheers,
Paul
