1)the design acceleration tab in Inventor 2012 is missing, the problem is still persist eventhought i reformatted and reinstalled the product
2) In windows explorer, when i right click on the inventor assembly file, the dialog box doesn't appear the ''pack and go'' adn ''design assistant''
And in Add-In manager? What you see?
Any more other Inventor release installed in your machine?
there is no design accelerator tab in my Add-In manager even i reinstalled it!
What can i do?
The Design Accelerator DLL reside in C:\Program Files\Autodesk\Inventor 2012\Bin\FDAddIn.dll
What you see in this directory?
If you Log In in with other windows user happens the same?
During Inventor instalation you:
Log onto the PC as the system Administrator?
Disable the Anti-virus?
I have the FDAddin.dll, but still I do not have the design tab. any help please?
Is there any solution for this, one of my customer having the same problems, but the design tab is there, only the command all gone.
He already try a clean uninstallation, there is nothing show Design Accelerator in Add in Manager.
He is using Autodesk Inventor 2010.
No, he ask the user to upgrade to other version. Actually Weiloon is my colleague but he just left the company.
My customer also still having the same problems, there is no solution for this yet.
Look at Maria's post from 2/16/2012 up above, with the Add In Manager shown. Do you see Design Accelerator in this window on your machine or the client's machine? That question doesn't seem to have been answered above.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I would try a clean uninstall then a fresh install
and see if that fixes it.
Or, maybe at this point and upgrade might be in order.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
NO,we already check the Add in Manager. for weiloon case n my case, we already try clean uninstallation but still the same.
the last thing he do is, upgrade the version. For my customer the don't upgrade their software, so no matter what, he still need to use 2010 version.
Well this annoying problem persists in Inventor Pro 2013 and 2014; both of which I have on my system.
I checked the add-ins manager for both versions, and both tell me that the Design Accelerator is loaded and is automatic on startup. The FDAddin.dll file exists for both versions in their respective folders.
Dear All,
The tab of "Design" will be visible while creating the "Assembly" and not in "Part". So create a new Assembly if you need to add gears and other stuffs.
Faraz Ahmad
AMU, Aligarh India.
Yes, we did it in Assembly, Wei Loon settel it by uninstall that version and install new version. For my case, the user still use that version.
