Inventor General Discussion
JDMather
Message 11 of 16 (185 Views)
Re: Derived surface not appearing in model
12-10-2012 06:46 AM in reply to: Justin_Desilva
jmather_at_pct_dot_edu
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
Justin_Desilva
Message 12 of 16 (182 Views)
12-10-2012 07:03 AM in reply to: JDMather
Got it, thanks.
Valued Contributor
Justin_Desilva
Message 13 of 16 (161 Views)
12-13-2012 01:04 PM in reply to: Justin_Desilva
Hi JD,
I sent you an email and wanted to confirm you received it.
Thanks again
JDMather
Message 14 of 16 (151 Views)
12-14-2012 07:04 AM in reply to: Justin_Desilva
No, or at least I don't think so.
I typically get dozens of questions every day - I don't keep track of them.
Valued Contributor
Justin_Desilva
Message 15 of 16 (145 Views)
12-14-2012 07:59 AM in reply to: JDMather
I double checked the emai l address and it looks accurate. Do you mind checking your spam folder for an email with my name on it?
Employee
csaba.stupak
Message 16 of 16 (125 Views)
12-17-2012 10:10 AM in reply to: Justin_Desilva
The given dataset contains composite surface (at least it looks like). The derived part command does not support derive of composite surface only surfaces and solid bodies. However derived assembly supports import of composite surfaces. You can try to insert the part into an assembly and derive the assembly, in the Others tab, expand the part instance node and include the composite surface.
Csaba
