Inventor General Discussion
2,122 Kudos
Post 11 of 16
Re: Derived surface not appearing in model
12-10-2012 06:46 AM in reply to: Justin_Desilva
jmather_at_pct_dot_edu
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
4 Kudos
Post 12 of 16
12-10-2012 07:03 AM in reply to: JDMather
Got it, thanks.
Valued Contributor
4 Kudos
Post 13 of 16
12-13-2012 01:04 PM in reply to: Justin_Desilva
Hi JD,
I sent you an email and wanted to confirm you received it.
Thanks again
2,122 Kudos
Post 14 of 16
12-14-2012 07:04 AM in reply to: Justin_Desilva
No, or at least I don't think so.
I typically get dozens of questions every day - I don't keep track of them.
Valued Contributor
4 Kudos
Post 15 of 16
12-14-2012 07:59 AM in reply to: JDMather
I double checked the emai l address and it looks accurate. Do you mind checking your spam folder for an email with my name on it?
Employee
5 Kudos
Post 16 of 16
12-17-2012 10:10 AM in reply to: Justin_Desilva
The given dataset contains composite surface (at least it looks like). The derived part command does not support derive of composite surface only surfaces and solid bodies. However derived assembly supports import of composite surfaces. You can try to insert the part into an assembly and derive the assembly, in the Others tab, expand the part instance node and include the composite surface.
Csaba
