If I understand meck correctly, he is using a very dangerous workmethod.
Folderstructure:
C:\Projects\Project A
C:\Projects\Project B
In Project A there's an IPT called "dummy part" which holds the parameters
for his design.
In Project B there's also an IPT called "dummy part", which holds the same
parameters (but with different values) as the "dummy part" in Project A
Now, he creates a part in Project A, derives the parameters from the "dummy
part" (from Project A). Let;s say this part is called "Beam.ipt"
At some time, he moves "Beam.ipt" from Project A to Project B.
When he openes "Beam.ipt" in Project B, he assumes that "Beam.ipt" mappes to
the "dummy part" of Project B.
Now if that's true, you are asking for big, big trouble (see the reply from
Pete)
So...
Why do you have a copy of your "dummy" part? Why do you move files from
Project A to Project B?
T. Ham
CAD Automation & Systems Administrator
CDS Engineering BV
HP xw4300 Workstation
Dual Pentium XEON 3.6 Ghz
4 GB SDRAM
NVIDIA QUADRO FX 3450/4000 SDI (Driver = 8.4.2.6)
250 GB SEAGATE SATA Hard Disc
3Com Gigabit NIC
Windows XP Professional SP2
Autodesk Inventor Series 10 SP3a
