Okay I will Sat it out and then try to read it back in. The process for the
parts are: We get the part data from our customer and have a outside company
translate our parts for us. I would post them on the files side of the news
server, but not sure if that would be a good idea because they are actual
parts from our customer.
"Udaya Gunasena (Autodesk)" wrote in message
news:276676524F0C8DF03BE1AD8D297A5549@in.WebX.maYIadrTaRb...
> Nathan,
> This error indicates a "boolean" failure. Typically this happens when you
> are trying to join two parts with complex geometry. In your case I
strongly
> suspect that your part's body is not in a healthy state. You could
probably
> confirm it by trying to add another feature like a hole to your part. You
> may also try to sat out the body and read it back in. (If your part body
is
> not bad, it's probably one of those cases where you have a difficult
boolean
> situations involving relatively simple geometry)
