Inventor Forum
Density, mass issue in inventor 2015
3 REPLIES 3
641 Views, 3 Replies
Just updated my Inventor 2014 to 2015 and now I have problem with density of materials, which I have created myself in previous Inventor releases. I have my own list of ISO steels: S355,S235 etc, with density 7,85 g/cm3, but now after 2015 update they all have density 1 g/cm3, it´s in template files and in old created part files also.  Old files are my major problem, because I have created thousands of files over years.
Haven´t had this problem in earlier Inventor versions.
Kind regards,
Nukkv6ll
3 REPLIES 3
Little update, I noticed that parts that I have created with older versions than 2014 are still OK, and some even 2014 created parts are OK. That is really strange, parts that are created at same day, one is with correct density and other is not. Same template is used and my default material is also the same.
t_hascj
Could you provide the steps to recreate this situation so we can reproduce the issue?
If it is dataset dependent, could you send us the dataset?
Jaroslav
mmoucka
in reply to: t_hascj
I have the same problem.
Have You please already found any solution ?
Thank You much, Martin.
