Inventor Forum
Density in lbs-in^3 ? How to get rid of the g/cm^3 units?
12 REPLIES 12
Message 1 of 13
1687 Views, 12 Replies
How can I change the density units by default: g/cm^3.
I'm working in imperial units, using : lbs-in^3
12 REPLIES 12
Message 2 of 13
Go to Tools/Document Setting.
Kathy Johnson
Message 3 of 13
Tools
    Document settings
        Units
Wolfe
How
Message 4 of 13
I mean when you go to:
Format - materials
Look at the density units...
Message 5 of 13
Should the settings under Tools - Document Settings - Units effect the default units under Format - Materials ?. I have all units set to Imperial but the material properties are still entered in metric units. Try to make a new material. What are the units? Thanks
Mike
Message 6 of 13
When I started using Inventor, I found the same thing. My VAR asked
Autodesk about it, and they said I couldn't change it. Autodesk also said
that they put it in metric, because for the most part that sort of
information was published in Metric more than Imperial. I think out of all
the materials I have created, I have only been able to find metric units in
1 case. I use www.matweb.com they have both Metric and Imperial.
Cory McConnell
BJ pipeline Inspection
Message 7 of 13
Alex123
I've always hated this too. Always have to convert when making a new material. Should have a choice!
Message 8 of 13
There are Inventor's internal units of measure. We just need to all go
metric anyway (and this is an American suggesting this)
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Cory McConnell" wrote in message
news:3B5CE7C9BED8FEF234E0F348523C2BBB@in.WebX.maYIadrTaRb...
all
in
> Cory McConnell
Message 9 of 13
I'll second that! ISO is a much cleaner system IMWO. Besides it's hard to
measure a foot and mine's only about 8 3/4" anyway.
~Larry
"Sean Dotson" wrote in message
news:3FE7B68C32F87B5684177BE9EE86EAFD@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
> all
> in
> > Cory McConnell
Message 10 of 13
...and you're both about to get your degrees in 1st angle projection too,
right?
8^Peer
"Larry Caldwell" wrote in message
news:C070812DDB77C875CDD586C3A13F0EFB@in.WebX.maYIadrTaRb...
> ~Larry
> > Sean Dotson, PE
Message 11 of 13
Is there some reason/advantage/necessity/whatever to choose one (1st vs.
3rd) over the other or is it just political; same reason we measure our
feet?
~Larry
"Peer Hoffmann" wrote in message
news:B5819FB655E13C552686587B4C731CA3@in.WebX.maYIadrTaRb...
> right?
> 8^Peer
to
> > ~Larry
go
> > > Sean Dotson, PE
Message 12 of 13
That ONE I'll never get used to
Sean Dotson, PE
Message 13 of 13
Peanuthead50
https://www.youtube.com/watch?v=dLRbowucVAE
I found the answer for anyone still looking. skip to 2:00
