Inventor Forum
Demoted parts - sub assembly cannot be saved or opened
7 REPLIES 7
Message 1 of 8
feet_first
766 Views, 7 Replies
I demoted some parts in the assembly browser and sucessfully made a sub assembly.  But I can't open it or save it.  I can edit it.  Once the top level assembly is saved the sub assembly I created is gone and nowhere to be found.  Has anyone else had this problem?  It is the first time for me.
Inventor 2011 Windows 7 64 bit
Tags (2)
7 REPLIES 7
Message 2 of 8
mrattray
in reply to: feet_first
After you create he sub assembly you need to save the top level assembly in order to create the new file.
Mike (not Matt) Rattray
Message 3 of 8
feet_first
I did save the top level assembly after I created the sub assembly before I posted this so I am still looking for a solution
Message 4 of 8
Hi feet_first,
Is it possible that Extrusion 6 was updset by the Demote action? If so, does deleting or fixing Extrusion 6 resolve the issue?
I hope this helps.
Curtis
Message 5 of 8
feet_first
Good observation but deleting it did not help.  Extrusion 6 did not affect any of the parts in the demoted assembly
Message 6 of 8
feet_first
I turned out the problem was with my PDM system (SolidWorks Enterprise PDM) .  The individual components you are planning to demote need to be checked out before you create the new sub assembly.  I did not need to do this workaround with Inventor Vault
Message 7 of 8
mrattray
Why would you use Dassault's PDM for Inventor files?
Message 8 of 8
feet_first
I use Enterprise PDM for Inventor files because it supports multiple CAD platforms better  and works better than Inventor Vault .  I have deployed and administered Inventor Vault, ProjectWise  and SolidWorks Enterprise PDM systems.  There are all about the same as far as purpose but you might not know what you are missing if all you have used are AutoDesk offerings.
