Inventor Forum
Demote vs. Replace Component
12 REPLIES 12
Message 1 of 13
506 Views, 12 Replies
Hi all,
Dennis Jeffrey told me that he could use Replace Component to replace a part
with an sub-assembly (containing that same part) while NOT loosing the
constraints to the "outer-world" (See topic "Demote - Wish" (22-09-2003,
13:54)). He even posted an example in IVCF, but I can't get it to work...
If Dennis is right, it could save me (all of us in fact) a lot of time
reconstraining the sub-assembly into the main-assembly!
Can anyone shed some light on this? (Dennis unfortunately stopped posting)
Thanks in advance,
Teun
12 REPLIES 12
Message 2 of 13
Dennis is correct.
Dennis is still here.
Charles made code to do this automatically so you don't wreak havoc on
an otherwise simple (but time consuming) process.
http://www.cbliss.com/inventor/iCode/index.htm
Get the Save n Replace macro.
QBZ
"Teun Ham" wrote in message
news:95977E3DBD516B32B56CDA9F7BF59F23@in.WebX.maYIadrTaRb...
> Hi all,
a part
(22-09-2003,
work...
posting)
> Thanks in advance,
> Teun
Message 3 of 13
Private Sub Small_Rant()
I still wish Dennis is correct...
I am glad Dennis is still here...
I know that Charles has made the Save n Replace marco...
I know that English is not my first language, but is my English so bad???
End Sub
I do know how to use the Replace Command to replace Parts with Parts, and
Assemblies with Assemblies within a Main Assembly. I will not loose any
constraints. Charles made a very nice marco (that could use some
improvements such as selecting the part/assy in the 3D view without
crashing).
What I want is to replace a PART with an ASSEMBLY (containing that same
part) while keeping ALL CONSTRAINTS to the "outer-world"! I say "with" an
assembly, not "within" an assembly!
Save n Replace cannot replace a part with an assembly, it can replace a part
within an assembly.
Dennis said it could be done, I stil don't know how.
I hope I am clear now...
Could still someone shed some light on this???
Teun
P.s. Thanks for the reply Quinn, no hard feelings 🙂
"Quinn Zander" wrote in message
news:BBEA2721F86816B9AD6BCAA954CE61F6@in.WebX.maYIadrTaRb...
> Dennis is correct.
> QBZ
> > Hi all,
> a part
> (22-09-2003,
> work...
> posting)
> > Thanks in advance,
> > Teun
Message 4 of 13
I would think that the only way to semi-automate the replacement of a
Part with an Assembly would be to define groups of iMates (called
Composite iMates) all of the same name (and the same order in the
composite group-the internal group doesn't have to be named to match-but
they have to be ordered).
The Sub would be constrained into the assembly with the Composite Imate.
When the Sub is deleted, the Composite in the assembly becomes
"available". When the part is inserted, check the "use iMate" in the
dialog and the part should fall right into place as it will have a
composite with the same name as the one in the assembly.
Unfortunately, it does not seem that the iMate interface is available
directly in the "Replace Component" dialog.
Perhaps someone would know if it is possible to access iMates during a
"Replace" through the API.
QBZ
news:7B5A8AF5AE4455B6D4D3B03C465A64F3@in.WebX.maYIadrTaRb...
same
an
Message 5 of 13
Teun
If it is any help, I am not able to replace a part with a assembly containing that part
either. I think if it was possible then we wouldn't be loosing constraints when demoting
a part in a assembly.
Not sure what Dennis was doing, but I think he might have misunderstood what you need.
If not we will both learn something 8^)
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
Message 6 of 13
See Inventor Customer Files
Quinn Zander wrote:
>Dennis is correct.
>QBZ
>>Hi all,
>a part
>(22-09-2003,
>work...
>posting)
>>Thanks in advance,
>>Teun
Dennis Jeffrey
Autodesk Product Consulting and Training
Center for Design Excellence
http://www.engineering-helpdesk.com
http://www.design-excellence.com
260-459-1311 ext 221 or 800-550-6070 ext 221
Message 7 of 13
Dennis
I am looking at the files. What are the steps you are saying to use to
take a part that is in a assembly, move or put it in a new assembly and
then replace the original?
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
"Dennis Jeffrey" wrote in message
news:3F75A2B9.1000805@design-excellence.com...
Message 8 of 13
Sorry, I lost the original text I sent to the newsgroup user..... It's
really simple.
1. Open assembly1 You will notice 2 parts in the assembly, test1 &
test2. Test1 is grounded and test 2 is constrained to test1,
2. Select Replace. In the screen or the browser, select test2. A
dialog will appear, so browse to
Weldtest.iam, which contains a weldment assembly with test2 as a part of
the assembly.
3. Done....... hope that clarifies things
Kent Keller wrote:
>Dennis
Dennis Jeffrey
Message 9 of 13
But Dennis after doing that there is no constraints between WeldTest and
Test1. Unless I am reading it wrong, that is the whole point of this
thread.
Kent Keller
Assistant Moderator
news:3F760432.30704@design-excellence.com...
> really simple.
of
> the assembly.
Message 10 of 13
You are correct..... I guess I've been burning way too many hours lately.
Dennis
>thread.
Dennis Jeffrey
Message 11 of 13
Been there done that 8^)
Kent Keller
Assistant Moderator
news:3F77A54E.9030501@design-excellence.com...
lately.
> Dennis
Message 12 of 13
While I know of no way to replace one component with another component that
is similar, I can offer a method that might alleviate some pain in some
circumstances. I apologize in advance if this is old advice readily
understood by regular participants.
Assuming you want to replace a part in an existing assembly with a modified
version of the part but do not want to modify the existing part file, the
following procedure will help:
1) Open the assembly and then open the part to be replaced within the
assembly.
2) Save a Copy of the part to be replaced and then close the part window.
3) Replace the part to be replaced in every instance where you require the
modified part - the constraints will still be intact.
4) Edit the new part as needed.
I use this process more often than I would have initially expected. I hope
you also find it helpful.
Sincerely,
Michael
Message 13 of 13
Thanks guys for all your efforts.
It seems like we still need to wait for the next release(s) untill we can
replace a part with an assembly while keeping ALL constriants.
Thanks again!
"Michael Trull" wrote in message
news:573D5B7634A3A914150019C99C17E6C3@in.WebX.maYIadrTaRb...
that
modified
> assembly.
> Sincerely,
> Michael
