I am building a large assembly that includes parts from the content center. When I go to demote some of the parts to create an assembly from them it will not allow me when I include certain parts form the content center. The parts it will not allow are Parker ball valves and an ANSI/ASME B16.15 Outside Head Bushing. It allows all other content center parts. I dont think I have to say how bad this sucks. I hope there is a fix that Autodesk can provide.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
I have not used the tube and pipe yet. I just insert them into the assembly form the contant center. It only does this with certain parts as I posted.
I have ran into this same issue before, even created a thread about it. I don't think my thread ever got any replies.
Whenever i've ran into this issue I just copied and pasted the parts into the sub assembly and reconstrained them. Not really a good solution but some times it's easier to just do that than screw around looking for a proper fix.
Niels van der Veer
The Netherlands
Very easy, select the parts you want to then on your keyboard select TAB. That will give you the menu you are looking for.
Good Luck 🙂
I found that demote doesn't work when you use "Part Priority". Hold "Shift + righ click with mouse" and choose "Component Priority" then try again. Hope this helps.
Using Inventor 2015.
