How do you constrain an object to the origin once the origin constraint has been deleted. I'm not really sure how it became unconstrained in the first place. When I try to constrain the drawing using the coincident constraint it won't allow me to select the origin.
Solved by MariaManuela. Go to Solution.
Hi george,
if you delete the original point, all you need to do is project the center point.
