Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Delete userparameter with ilogic
2 REPLIES 2
theo.bot
5234 Views, 2 Replies
Dear,
I know how to add user parameters with ilogic, but i would like to dete them as well. I've tried to use the delete option as mentioned in the API help but I cann't get it working in ilogic.
any one a suggestion, this is how i create a parameter:
Format:HTML Format
Version:1.0
StartHTML: 165
EndHTML: 3855
StartFragment: 314
EndFragment: 3823
StartSelection: 314
EndSelection: 314
DimoDocAsPartDocument=ThisDoc.Document'of : oDoc as AssemblyDocumment = ThisDoc.Document
'nummerieke parameter
Try
prop=oDoc.ComponentDefinition.Parameters.UserParameters?.item("nummer")
Catch
newprop=oDoc.ComponentDefinition.Parameters.UserParameters?.AddByExpression("nummer", "100", "mm")
EndTry
greetings,
theo
Tags (2)
2 REPLIES 2
theo.bot
in reply to: theo.bot
Found the solution:
Format:HTML Format
Version:1.0
StartHTML: 165
EndHTML: 1602
StartFragment: 314
EndFragment: 1570
StartSelection: 314
EndSelection: 314
DimparamAsParameter
param=oDoc.ComponentDefinition.Parameters.Item("G_L")
param.Delete
Maybe it's intresting for other users!
Kind regards,
Theo
Guthery1
For users on newer versions.  Here is an updated script that works in 2023:
Dim doc = ThisDoc.Document
Dim param As Parameter
param = doc.ComponentDefinition.Parameters.Item("PARAMETER NAME")
param.Delete
Just replace "PARAMETER NAME" with the actual parameter name you want to delete and you are all set.
