Inventor General Discussion
celesiob
Message 1 of 6 (276 Views)
delete rule with internal macro vba?
276 Views, 5 Replies
11-08-2013 05:19 AM
good day,
someone from the forum knows the code to delete an internal rule of a document using a macro vba?
thank you in advance for now.
I found a solution to my problem, the following code deletes all the rules of the active document serves to cituação mine, but if anyone knows a way to delete a certain specific rule by name I would appreciate it.
Sub deleteRULE()
Dim i As Object
Set i = GetiLogicAddin(ThisApplication)
Dim oDoc As Inventor.Document
Set oDoc = ThisApplication.ActiveDocument
'' This will delete all rules in the document
Call i.DeleteAllRulesInDocument(oDoc)
End Sub
Function GetiLogicAddin(ByVal oApplication As Inventor.Application) As Object
Dim addIns As ApplicationAddIns
Set addIns = oApplication.ApplicationAddIns
Dim addIn As ApplicationAddIn
On Error GoTo NotFound
Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
If (addIn Is Nothing) Then
Set GetiLogicAddin = Nothing
Exit Function
End If
Call addIn.Activate
Set GetiLogicAddin = addIn.Automation
Exit Function
NotFound:
End Function
Distinguished Contributor
m.teleguz1
Message 2 of 6 (256 Views)
Re: delete rule with internal macro vba?
11-08-2013 08:38 AM in reply to: celesiob
Why would you want to do that? Go to ilogic, rules, select the rule and delete.
Image and video hosting by TinyPic
Privacy warning: Since I live in a country that has traded liberty for the illusion of security, all of your posts to me are being monitored and saved by the United States Government.
See My LinkedIn Profile
m.teleguz1
Message 3 of 6 (250 Views)
11-08-2013 08:40 AM in reply to: celesiob
Check this post out.
http://forums.autodesk.com/t5/Inventor-Customization/Delete-iLogic-rule-using-VBA/td-p/3082010
celesiob
Message 4 of 6 (244 Views)
11-08-2013 08:46 AM in reply to: m.teleguz1
the company where I am working on a customization was initially conducted using iLogic due to complessidade this need for customization and aperfessuar the same, we are migrating to vba, however constumização generates complito old with the new, due to existing internal parameters, and avoid this problem the best solution is to eliminate the old rule exists internally in the file, because all actions are performed through a form created in vba, I hope you consseguido justify my need.
celesiob
Message 5 of 6 (238 Views)
11-08-2013 08:50 AM in reply to: m.teleguz1
I've tried using this code but not watch out for my purpose, my goal is elimiar the existing rule only when necessary, such a solution is to delete all the rules in a specified folder. that is not what I precisso, already tried adptar the same for my situation and not got success.
celesiob
Message 6 of 6 (207 Views)
11-27-2013 10:58 AM in reply to: celesiob
Sub deleteRULE()
Dim i As Object
End Sub
Exit Function
End If
Call addIn.Activate
Exit Function
NotFound:
End Function
