Inventor Forum
Delete Part Fillet Feature??
2 REPLIES 2
1167 Views, 2 Replies
Hello Experts!!
Can you delete part of a  fillet feature? While still keeping part of it & adding to it.
I have a fillet feature with 2 fillets to a part. One is in the wrong place.
The Feature Fillett1 if you edit it, you will see what I mean.
Keep the middle one. Both fillets are 0.25"
Replace the bottom fillet to the top corner.
I would like to keep the Feature in the order it is in, if possible.
I am using Inventor 2012.
Kind regards
A Student.
2 REPLIES 2
JDMather
Edit the Fillet feature
Ctrl Click the edge you don't want filleted.
(you could now select the edge you do want filleted - but I wouldn't do that as you have already created some dependencies on that edge)
Select OK and then add the fillet at the bottom of the history tree.
mcgyvr
You can edit the feature and use the "CRTL" button to deselect and edges you don't want.
