Independent option only shows up when you rmb on the element node. You can
also edit the pattern and add/remove elements. Are you just trying to
remove one part of a sub-assy, from one instance of a pattern?
Sam Hochberg
Inventor Certified Expert
Not too bad at AutoCAD either
wrote in message news:4860518@discussion.autodesk.com...
These are my options when I rmb.
