I was wondering if there was a keyboard shortcut for the degree of freedom analysis with animate which is found under the productivity drop down menu ? Many thanks
Pretty sure there isnt a default shortcut to it.. but you can customize Inventor with your own shortcut
Tools / Customize / Keyboard .. scroll down and find the command .. set the shortcut to the left of the command.
Thanks for that, I suspected there wasn't one too, I'll get a customized shortcut as you suggested.
