Inventor Forum
defining range of motion
2 REPLIES 2
JohnHerbert
159 Views, 2 Replies
hi all - i wanted to know if there is any way to limit the range of motion of a part. i need to limit the range of motion of a piston to be four inches of travel. currently the picton is constrained to be concentric with the housing it is in, but once the assembly is put together the piston can be dragged through the housing . . . .
Thanks so much -
2 REPLIES 2
in reply to: JohnHerbert
There is a workaround way defined at my site.
See Inventor tips & tricks 2011 http://www.mymcad.com/
I havent tested to see if this still works in R6
- drew
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Member of the Autodesk Discussion Forum Moderator Program
Visit my MCAD website @ http://www.mymcad.com/
"JohnHerbert" wrote in message
news:f12a34a.-1@WebX.maYIadrTaRb...
> Thanks so much -
"I havent tested to see if this still works in R6"
It does..
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
"Drew Fulford" wrote in message
news:57EFF194DFC2C562E9011DB2C6E286E1@in.WebX.maYIadrTaRb...
> - drew
motion
inches
> > Thanks so much -
