Inventor Forum
Define new material for library parts?
8 REPLIES 8
Message 1 of 9
611 Views, 8 Replies
Is there anyone that have tryed to define new material to library\standard parts?? and how did you do it.
regards
Svein
8 REPLIES 8
Message 2 of 9
I would suggest looking At a tutorial at www.sdotson.com
Have a look, and if you are still having trouble, post back.
Cory McConnell
BJ pipeline Inspection
"Svein" wrote in message news:f11fc31.-1@WebX.maYIadrTaRb...
> regards
> Svein
Message 3 of 9
Hi. I had to post back:-(
Didn`t find what I was looking for.
What I want to do is to make\define new materials to add to the parts in IV6 library\content library
and save it to the template file so that I can add it to library files later also.
Regards Svein
Message 4 of 9
Open your ipart or your template. Go to Format> materials. Set up your new
Material here. You can find info about alot of materials at www.matweb.com
. (The units are in Metric and you can't change that - Autodesk states that
all Material Specs are in Metric??!?) Set your rendering style if you want
and exit. Open the opposing file, and go to Format> Organizer. Browse to
the original file, select the material you want to copy, click copy, and
exit out of organizer. Your Material will be in the properties "Physical"
tab pulldown.
Is this what you wanted?
Cory McConnell
"Svein" wrote in message news:f11fc31.1@WebX.maYIadrTaRb...
later also.
> Regards Svein
Message 5 of 9
No, Sorry:-(
The "organizer" isn`t available when you try to edit a part from IV6 Library(content Library R5.3)
Regards Svein
Message 6 of 9
He told you to edit the Template, not already defined parts.
Update the catalog template and create new library parts.
Jorgen
Message 7 of 9
Oh sorry, I misread your first post. You can't change the materials of
standard parts. You also have no way of controlling what they put in your
part list. I use iparts. Alot more versatile.
Cory McConnell
"Svein" wrote in message news:f11fc31.3@WebX.maYIadrTaRb...
> No, Sorry:-(
> Regards Svein
Message 8 of 9
Hi
I know this was the method in earlier version but it doesn`t work in R6. (Not for any one here anyway)
Is there any one that have added\defined new material to screw, nuts,bearings, etc, etc in R6??
Regards Svein
Message 9 of 9
Ok
Thanx
(something for Autodesk???)
Svein
