Inventor General Discussion
Member
kvfertig
Message 1 of 4 (152 Views)
Default Template Messed Up?
152 Views, 3 Replies
03-30-2014 06:48 PM
Heyo, so I'm a freshman high schooler (please keep this in mind when responding), so I'm not a professional at Inventor or anything. My engineering coach (I go to a STEM school so we call teachers coaches) installed Autodesk Inventor 2014 onto my Windows 7 i7 laptop (8GB RAM?). Anyways, after Inventor started bugging me, I started searching around. I think that my Default Template is messed up. I guess that's where customization happens? Anyways, it started when I tried downloading and converting a DXF 3D sketch into an IPT through TrueViewer. Some error always happened mentioning a default template, so I decided to make the linear actuator piece myself. When I clicked "New," the image was all weird unlike the desktops that have Inventor in my engineering classroom. The link to the distortion is here: http://imgur.com/gusm9OW. What I think is a hyperlink doesn't seem to work. I can go around it pretty easily, but it's a bit annoying. The final straw was when I noticed my dimensions were weird after two hours of work. When I went to change them, it was on centimeters! I figured out how to go to Options -> FIle -> Configure Defaut Template (Thank you Autodesk Community!), but it said the default WAS in inches. I tried restarting the program, but the same thing happened. It's stuck in cm and I have to use a conversion. So anyways, does anyone have any clue on what's wrong with my Inventor/Default Template? I think maybe some important file was touched in my computer, but I don't know. Before I go to my engineering coach I wanted
Member
kvfertig
Message 2 of 4 (150 Views)
Re: Default Template Messed Up?
03-30-2014 06:49 PM in reply to: kvfertig
*wanted to ask you guys about it.
Thanks!
-Kyle
blair
Message 3 of 4 (125 Views)
03-30-2014 07:59 PM in reply to: kvfertig
here is a fresh set of Inventor 2014 stock templates, These should be copied to your: Libraries>Documents>Austodesk>Inventor 2014>Templates>English directory. The Standard.idw should be copied to your: Libraries>Documents>Austodesk>Inventor 2014>Templates directory
IV2015 up2 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Member
kvfertig
Message 4 of 4 (97 Views)
03-31-2014 07:02 AM in reply to: blair
Thank you! I didn't even have those two folders, so I made made them myself. I extracted stuff out of the ZIP, and it works now! Thanks again!
-Kyle
