Hi all,
Finally making the upgrade from 2013 to 2015 (skipped 2014) and trying to get the templates set-up for use.
I'm having trouble with the Revision Block and the Parts Lists tables to justify correctly per our standards. I can edit them 'after placement' by the format column option, but they will not come in correctly by default, like they were in 2013. There must be a setting somewhere that I can't seem to locate. Any suggestions?
In the attached picture is the same two tables:
Top is 2013
Bottom is 2015
Larry
Inventor 2015, Update 1
Dell Precision M6600
Windows 7 Professional - 64Bit
32 GB Ram
Nvidia Quadro 3000M
Solved by mrdelicious2. Go to Solution.
Larry,
Have you migrated the Design Data from 2013 to 2015? See the below link for detail.
http://www.inventortales.com/2014/05/getting-ready-for-autodesk-inventor_9.html
Is it possible to just update the styles in 2015 to correct the issue? This may be the fastest solution.
If you have migrated, perhaps there is an issue that occurred during the migration.
Would it be possible to perform a Pack and Go on a drawing containing the issue and e-mail it to me? It would be helpful to have both a 2013 version and a 2015 version of the drawing. This would enable me to reproduce the problem on my end by migrating the data myself.
When you do a Pack and Go of the drawing, can please disable the Skip Styles and Skip Templates option in the Pack and Go dialog. This will include the Design Data and Drawing templates in the pack and go which will be necessary to migrate and ultimately, reproduce the problem. Feel free to e-mail direct at Nathan (DOT) Chandler (AT) Autodesk (DOT) com.
Thanks for the reply. I did NOT migrate the 2013 styles. I started with default 2015 styles and tried to make all the updates from scratch. There really isn't too much that we change and wanted to make sure that we were destroying some of the new functionality by migrating old data. I will try to get a detail uploaded that demonstrates the issue.
Thanks!
Thank You Nathan from Autodesk for pointing this out.
You can get the format for justification by left clicking on the left side of the property button, like in the attached screenshot.
Thanks again for the help!
Larry
