Can you have more "Object Defaults" then there is standards?
I ask because everytime I create an additional one and don't have a standard for it to link to
and I save the styles it disapears.
Solved by Curtis_Waguespack. Go to Solution.
Hi Cadmanto,
Are they just getting filtered, by chance?
I hope this helps.
Curtis
Curtis,
Yes they were. Thank you. This was one of those moments when I was scratching my head along with a co-worker.
Now that you have brought this to light it makes sense after saving this setting to the styles why it wouldn't bee seen under the local filter.
Thank you again.
