Inventor General Discussion
Active Member
priit
Message 1 of 3 (136 Views)
Default layers and settings for template
136 Views, 2 Replies
01-28-2014 06:07 AM
Hi
Is it possible to use default layers for template? I'm trying to achieve a template that has predefined layers and settings to fasten my job. But if i start a new drawing and choose my predefined template, all layers are black (allthough in template file the layers are with different colors). The same with text size, tolerance precision etc.
What am I doing wrong, or it isn't possible? Really time consuming to edit layers and settings with every new drawing. Style editing is allowed in project file.
Hi!
You have to create a new style, save the style and save the file as template.
GO to manage, edit Styles (1) and create a new style... can be a copy from the standard and then edit it. Save the Style (2) and save this edited document as a template.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Distinguished Mentor
ccarreiras
Message 2 of 3 (129 Views)
Re: Default layers and settings for template
01-28-2014 06:29 AM in reply to: priit
Hi!
Regards.
CarlosC
Autodesk Inventor 2014 Certified Professional
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
Active Member
priit
Message 3 of 3 (123 Views)
01-28-2014 06:46 AM in reply to: ccarreiras
Finally, thank you very much!
