Inventor General Discussion
jrittenhouse
Message 1 of 6 (198 Views)
Def Points layer
198 Views, 5 Replies
11-08-2012 02:54 PM
How can I delete a def point layer after the program says i can not?
Valued Mentor
jclaidler
Message 2 of 6 (174 Views)
Re: Def Points layer
11-09-2012 06:30 AM in reply to: jrittenhouse
Defpoints in 'Inventor'?
____________________________________________________________________________________
AutoCAD 2014 | Inventor Professional 2014 | Vault Professional 2014 | Navisworks Manage 2014
Autodesk Certified Professional: AutoCAD 2014
25 years of Autodesk Application Experience
jrittenhouse
Message 3 of 6 (159 Views)
11-09-2012 09:02 AM in reply to: jclaidler
Def points in AutoCAD.
Valued Mentor
jclaidler
Message 4 of 6 (155 Views)
11-09-2012 09:14 AM in reply to: jrittenhouse
This is the 'Inventor' group.  But why would you want to delete 'defpoints'?  You can't delete that layer anyway, AutoCAD uses it for certain objects created.
*Pro
ampster
Message 5 of 6 (146 Views)
11-09-2012 10:28 AM in reply to: jrittenhouse
one way is to rename defpoints then purge.
Valued Mentor
jclaidler
Message 6 of 6 (144 Views)
11-09-2012 10:31 AM in reply to: ampster
Yes, you can rename the layer.  But once a dimension is placed, defpoints is created again.
Best option, leave it alone.
