Question: Where can I find a list of the Autodesk Knowledge Network support solutions that were created and / or updated in the month of December?
Week One:
Additional Custom material library in subfolder after Pack & Go
After starting Inventor process uses 100% of a core and some buttons are not working
Auto numbering is not executed immediately in hole table
Cannot choose a hose fitting in tube and pipe styles after deleting the partnumber
Description Text changes are applied to all type when table is split
Entire geometry in under-constraint color after Copy & Paste in Sketch
Material library not loaded correctly after switching project
Performance issue when edit the thread feature of an iPart with only Office 2013 applied
Pressing Enter after changing Thread Depth value generates an error
Reference geometry is not visible in drawing view with Background updates
Saving not possible after opening assembly from drawing
Section line thickness behavior under a certain value of the layer thickness
Ungrouped flyout commands cannot persist on QAT
Week Two:
A section is not inherited in another section view
Automatic Contact and Mesh command product no results in Inventor Stress Analysis
Changing Inventorās Content Center from local to Vault crashes Inventor
Discrepancy between Inventorās Involute Spline Connection Generator and ANSI standard tables.
Driving a constraint or a joint generate a CER of Inventor
Invalid (Missing) sketch detected by Design Doctor
Inventor 2014 shrinkwrap performance issue
Inventor 2014 will not check in files to Vault 2014, server timeout error.
Inventor 2015 crashes on editing a pattern
Inventor 2015 Decals are failing to go throughth Suite Workflows
Inventor 2015 goes to a CER when selecting properties during plotting for an HP Designjet 1050C Plot...
Inventor Background images are rendered darker in Ray Tracing mode
Inventor dialog boxes are being covered up while performing a Ray Trace
Inventor Drawing views have missing lines
Inventor fails to calculate the Physical properties
Inventor not Automatically Creating A-Side Definitions with the Flat Pattern
Inventor: Creating Extrusion or Revolve Between Work Planes Fails
Inventor: Emboss Function is failingProblem with Emboss function
Inventor: Rotated text when importing Visio documents
Limitation of export in Vector format
Performance issue with Inventor 2015 with top down assembly design
Plan between surfaces does not update correctly in the generated iPart members
Printing of drawing file to a sharp printer crashes Inventor.
Some NX .prt files cannot be opened in Inventor 2015
Switching from welds to machining of state model generates incorrect representation
Updating existing assembly feature has no effect on components
Wires in Inventor 2013 Cable & Harness are not rendering
