I think this stated problem was solved, but I thought I might be able to help folks who find this thread from another blurry image issue instead of creating a new thread.
I had a model with a decal based from a bmp file that looked satisfactory, but the drawing was quite blurry. Nothing I tried (including messing with the model as suggested above) helped the view in the drawing which was from a previous version of inventor. The only thing I was able to figure out was to create a completely new drawing file (in 2010 format).
@Anonymous wrote:I think this stated problem was solved, but I thought I might be able to help folks who find this thread from another blurry image issue instead of creating a new thread.
With the drawing open..Go to..tools..document settings.. Drawing tab.. in the "shaded views" section change "use bitmap" to "offline only" then you can also change the bitmap resolution there too.
That should fix it.
I have my drawing template set to "offline only" and 100 DPI so its always set like that.
That should fix it.
yep. that was it! Thanks a bunch - this certainly is much more elegant than what I came up with.
JL
