Inventor Forum
DATABASE SCHEMA - AGAIN FOR INVENTOR 11
8 REPLIES 8
Message 1 of 9
dannyc2
1524 Views, 8 Replies
I have looked at numersous Database Schema is newer than this version of the software help files.
NONE of them fit the problem.
I have un-installed and re-installed the SAME INVENTOR 11 that created the original files.  When trying to open the files (that this particular program created) I get the above error message.
NO other versions, test, samples, views or any other product has been installed, removed, or otherwise started and stopped.
1)  So, why doesn't the original program open its own files?
2)  How do I access the hundred plus files that this program created?
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: dannyc2
Attach example *.ipt file that Inventor "11" won't open.
Message 3 of 9
JDMather
Did you ever find the file?
What does iProperties report?
Message 4 of 9
dannyc2
I can EDIT this Reply but can't edit original - Edit Function not available
How to you attach files here?
I've replied to e-mails with attachments but to no avail
Attached are two files ipt and iam
Message 5 of 9
JDMather
Not sure why you would be getting this problem, but iProperties would seem to indicate that you have not installed Service Packs or Hot fixes (updates) for  that release.  Not sure where you would find those for an old release.
Message 6 of 9
dannyc2
in reply to: JDMather
Checked - 4-12-14 - and it says my program is UP TO DATE.
LIVE UPDATE MAINTENANCE PATCHES is grayed out.
I checked in Communication Center
Message 7 of 9
JDMather
What does your Help>About Autodesk Inventor say is your current SP?
Message 8 of 9
dannyc2
No longer a problem - on either computer
The original one (XP) is now DED (dead - won't work at all)
The New one (Win 8.1) won't even start. It used and give the same SCHEMA problem - Now it doesn't even start.
Thanks for the help - much appreciated.
Message 9 of 9
JDMather
This is the first time you mentioned trying to run Inventor 11 on Win 8 OS.
http://forums.autodesk.com/t5/Inventor-General/Inventor-11-and-Windows-8-1/td-p/4955468
