Have you tried creating a project file with the library paths as
workgroup paths, then create your tank project files and add the library
project file as the "included file" entry. this should allow you to
reference your libraries, open a library part and edit it whenever you
need to, and copy that file with the other project files in DA.
Matt Hendey wrote:
> Most of my projects are tanks. The projects are small 25 to 100 parts. With
> every new tank I try to find the closes tank that we have done already.
> Sometimes this could be one of our standard tanks that have standard parts
> (Library Parts) in them that will have to be modified to create the new
> custom tank. When I DA the standard tank, from the IDW down, I will want to
> copy that library part with the tank because I know it will be modified. But
> I can't because it's a library part. So, I will continue to copy everything
> else then when I open the new assembly I will save the library part as the
> new non library part that will need to modified. Then I will replace the old
> library part with the new custom part before it's modified so that I will be
> able to retain all the constraints. After this I can then again open the new
> non library part and make the desired changes.
> This would be a lot simpler if I could have copied the library part over in
> DA with the rest of the tank (project) in the beginning.
> I'm not griping but the new, library, read only, functionality seams to be
> more for the multi-user environment. I find that, so fare, it has not been
> of any use to me as a single user. In fact it seams to make things a little
> more difficult, and it does have some loop holes.
> Thanks,
> Matt
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4472 w/registry update
Dell UltraSharp 19" LCD
