Inventor General Discussion
Valued Contributor
mdwildcat
Message 1 of 17 (675 Views)
Cylinder unfold to creat layout.
675 Views, 16 Replies
05-27-2009 01:04 PM
I want to creat a hollow cylinder. But I need to be able to unfold it to have a layout of the cylinder. So that when this DWG goes to the floor the technicans knows how much he/she will need from the sheet to roll the cylinder.
Mark_Flayler
Message 2 of 17 (676 Views)
Re: Cylinder unfold to creat layout.
05-27-2009 01:10 PM in reply to: mdwildcat
Which Version of Inventor?
In 2010, create your hollow cylinder as a sheet metal part, use the Rip command to create the opening, use a Flange with Old Method to lap if desired, hit Flat Pattern, save a copy of the face as a DXF.
Mark Flayler - Senior Application Engineer
IMAGINiT's Manufacturing Solutions Blog:
http://blogs.rand.com/manufacturing/
mcgyvr
Message 3 of 17 (676 Views)
05-27-2009 01:13 PM in reply to: mdwildcat
You will need to test and enter in a value for the k-factor/bend allowance which is based on which machine you are using to roll and how much it will stretch the material when rolling it.
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Valued Contributor
mdwildcat
Message 4 of 17 (676 Views)
05-27-2009 01:14 PM in reply to: mdwildcat
we are still using 09 we are having problems getting 10 to work on all the computers.
Active Member
nick.s
Message 5 of 17 (676 Views)
05-27-2009 08:09 PM in reply to: mdwildcat
If you draw your cylinder as a sheetmetal part using contour flange you can layflat this. Sketch would be of circular end and must have a break (can be very small) in it. As stated above you'll want to have appropriate sheetmetal settings applied.
Valued Contributor
mdwildcat
Message 6 of 17 (676 Views)
05-28-2009 05:17 AM in reply to: mdwildcat
When I do this using the contour flang operations I get this error message:
Sheet Metal: Contour Flange Creation failed.
Part1: Errors occurred during update
Closed loop found in this path. Use Edit Sketch to open the loop.
Non-tangent curves found in path: flat pattern cannot be correctly created. Edit sketch and add constraints to the curves.
Feature Compute failed.
Mark_Flayler
Message 7 of 17 (676 Views)
05-28-2009 05:19 AM in reply to: mdwildcat
Contour Flanges require an Open profile such as a line or arc or series of these, not a normal close profile you may be accustomed to.
JDMather
Message 8 of 17 (676 Views)
05-28-2009 05:26 AM in reply to: mdwildcat
>When I do this
Attach what you have so far.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Member
nick.s
Message 9 of 17 (676 Views)
05-28-2009 01:16 PM in reply to: mdwildcat
Yes, as other post states the sketch would be a single circle with a break not circle with offset and ends closed like normal profile. Contour flange looks for reference edge not profile. Apologies for the jpg - it wasn't very clear. The break would be very small so as to have a negligible effect on the layflat width.
Valued Contributor
johnteng00
Message 10 of 17 (631 Views)
05-28-2009 06:51 PM in reply to: mdwildcat
the addin from solid3dtech is different than the functions inside Inventor. It can handle "not developable" surface or quilt surface.
