Inventor Forum
cylinder insert
18 REPLIES 18
Message 1 of 19
nicoskylark
415 Views, 18 Replies
cylinder insert
Hi, i have a problem, i need insert a cylinder into inner diameter of a ball bearing, logically it must rotate with the bearing but no, the bearing outer diameter is fixed to a support and works well, but when i insert the cylinder into the ball bearing it's fixed completely and the cylinder rotate into the inner diameter, can somebody help me please? Thanks
18 REPLIES 18
Message 2 of 19
JDMather
in reply to: nicoskylark
Attach your assembly here.
It sounds like you might need to set a sub to Flexible, but without even a screen capture....
The CADWhisperer YouTube Channel
Message 3 of 19
nicoskylark
I neee simulate the movement of an axis into a ball bearing basically, how can i send a screen capture?
Message 4 of 19
Cadmanto
If you are using Windows 7 there is a tool under the accessories when you select the start button that is called the
This will allow you to crop and capture screen shots to post here.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 5 of 19
JDMather
@nicoskylark wrote:
I neee simulate the movement of an axis ....
Translational or rotation?
Message 6 of 19
nicoskylark
Rotation
Message 7 of 19
JDMather
Still no assembly attachment?
Still no screen shot?
Message 8 of 19
nicoskylark
Now i'm not in front of my PC, when i arrive home i'll try
Message 9 of 19
nicoskylark
Hi again, now I´ll show you the screen capture. Before I make the relationship with the right piece I can rotate the ball bearing into his holder, but when I insert the other piece I can´t rotate the ball bearing as before, and the other piece rotate in his axis but no with the ball bearing, please tell me if I´m not enough clear.assembly.png
Message 10 of 19
JDMather
@nicoskylark wrote:
..the other piece rotate in his axis ....
This last part doesn't make sense.  This part should have 6 degrees of freedom (no constriants) before constraining to the bearing.
Message 11 of 19
nicoskylark
The other piece must rotate with the ball bearing, not only the other piece and the ball bearing fixed to holder. Do you want I attach the assembly file and his parts?
Message 12 of 19
nicoskylark
Thats the last part. The assembly have more pieces but only that three pieces give me problems.
Message 13 of 19
JDMather
What happened to your dimensions?
Where did they go?
How did you create sketches without dimensions?
A 12mm hole is the wrong size for a 12mm thread - there will not be any material for the fastener to attach.
Use the Hole feature to make tapped holes, not Extruded circles.
(see attached image)
Before moving to more advanced topics like assembly constraints - I recommend going through these
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
You assembly works as expected for me, but missing a lot of parts.
I assume you want to Mate workplane of Maza to Rodamiento, but the bearing is made as one part rather than as an assembly like a real bearing - so it is not going to work exaclty like a real bearing.
Message 14 of 19
JDMather
in reply to: JDMather
Edit Sketch5 as in image.
Right click and Show All Constraints.
What do you see?
It is better to make a simple sketch and feature and then pattern the feature rather than the sketch.
Message 15 of 19
nicoskylark
The dimension, once the sketch is ok, I did erase it. Now I could solve my problem, all the parts who must rotate together I defined as a sub assembly, then I place it into the ball bearing holder using the ball bearing axis, now works perfectly. Thank you very much for the help and forr quick answer.
Message 16 of 19
JDMather
Do not erase dimensions.
Message 17 of 19
nicoskylark
I have another problem, when I want animate the assembly in inventor studio the gears doesn't move, they have constraint of motion. The assembly is too big, I attached it to Skydrive in http://sdrv.ms/1faJeVz
Message 18 of 19
JDMather
Find the red End of Part marker in the browser.
(End of Folded on sheet metal parts EOF)
Drag the red EOP to the top of the browser hiding all features.
Save the file with the EOP in a rolled up state.
Right click on the file name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
Message 19 of 19
nicoskylark
I can see that End Part marker in the parts, but no in the Assembly, should I do that only in parts and attach the assembly file directly?
