Inventor General Discussion
Member
northweststavecody
Message 1 of 6 (2,447 Views)
Cutting out material in assembly view using a second piece
2447 Views, 5 Replies
04-11-2011 04:52 PM
I am wondering if there is a way to use a part of one piece located in an assembly to cutout a portion of another piece located in an assembly when both pieces occupy the same space?
The situation I'm in is that I've got an L bracket (piece 1) resting on top of a piece representing a concrete block (piece 2).  The L bracket has metal studs attached that protrude into the concrete. Idealy I'd like the mass of concrete located in the same space as the studs removed so that when I generate cross sections everything adds up.
Any help is much appreciated,
Cody
JDMather
Message 2 of 6 (2,443 Views)
Re: Cutting out material in assembly view using a second piece
04-11-2011 05:51 PM in reply to: northweststavecody
Edit the part to be cut within the context of the assembly.
Right click and Copy Object as surface the faces of the second part into the first part.
Use Split part or Sculpt to cut the first part.
Attach your assembly here if you can't figure it out.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
northweststavecody
Message 3 of 6 (2,399 Views)
04-12-2011 10:26 AM in reply to: northweststavecody
Thanks for the help. I gave it a shot but was unable to solve the problem.
 I was able to copy and create a surface in parts bracket 13625L and bracket1352 redo:1.
Hoever I could not manage to get these surfaces to interact or move to Grating Oil Water Sump v2:1 (the part that I'm trying to cut). I've attached the assembly. hopefully it helps solve the problem.
JDMather
Message 4 of 6 (2,379 Views)
04-12-2011 01:17 PM in reply to: northweststavecody
Curtis_Waguespack
Message 5 of 6 (2,363 Views)
04-12-2011 02:47 PM in reply to: northweststavecody
Hi northweststavecody,
In addition to JDMather's help, this link might offer some assistance:
http://inventortrenches.blogspot.com/2011/03/find-interference-and-add-tolerance-to.html
I hope that helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
New Member
mark.d.jackson
Message 6 of 6 (1,775 Views)
12-14-2012 08:09 PM in reply to: northweststavecody
What about using an iFeature to do the material removal?
