Inventor General Discussion
Active Member
nick.jeuris
Message 1 of 16 (848 Views)
Cutout appearance doesn't work
848 Views, 15 Replies
09-20-2012 07:03 AM
I have a problem when I want to use a cutout.
My purpose is to get a perforated plate but Inventor doesn't show this.
Only the black color is shown and not the holes.
What am I doing wrong?
Thanks in advance
Nick
Cadmanto
Message 2 of 16 (844 Views)
Re: Cutout appearance doesn't work
09-20-2012 07:09 AM in reply to: nick.jeuris
Make sure the "cut" is selected in the command dialog window.
I can't open your file because I am still on 2012.
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
*Pro
ampster
Message 3 of 16 (829 Views)
09-20-2012 07:26 AM in reply to: nick.jeuris
if you're just using that .png file to similate perforated plate, the cut away won't work.
Active Member
nick.jeuris
Message 4 of 16 (828 Views)
09-20-2012 07:30 AM in reply to: Cadmanto
Hi Cadmanto
I'm not doing an extrude, but I am using the cutout option in the appearance menu.
See the screenshot in attachment.
Nick
Active Member
nick.jeuris
Message 5 of 16 (825 Views)
09-20-2012 07:32 AM in reply to: ampster
What's wrong with the .png file?
mrattray
Message 6 of 16 (802 Views)
09-20-2012 07:55 AM in reply to: nick.jeuris
I'm not sure what you did wrong, but after I cleard your overrides and set generic to use your image file it worked fine.
Mike (not Matt) Rattray
Cadmanto
Message 7 of 16 (801 Views)
09-20-2012 07:59 AM in reply to: nick.jeuris
Sorry I misunderstood your issue.
2 thoughts, first maybe the transparency needs to be adjusted on the png file
and second, can you use this appearance in the color portion of the style and standard editor?
Best Regards,
Scott McFadden
mrattray
Message 8 of 16 (799 Views)
09-20-2012 08:01 AM in reply to: Cadmanto
You forgot that there are no longer colors in 2013. He has to work with the appearance editor.
JDMather
Message 9 of 16 (791 Views)
09-20-2012 08:06 AM in reply to: Cadmanto
..... Styles and Standards, Materials and Colors questions based on 2012 and earlier releases.
It has all changed in 2013.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Cadmanto
Message 10 of 16 (762 Views)
09-20-2012 09:20 AM in reply to: mrattray
Alrighty then...:smileyfrustrated:
I am still on 2012, so I guess I have something to look into.
Thanks for the heads up guys.
Best Regards,
Scott McFadden
