Inventor General Discussion
Active Member
1 Kudo
Post 1 of 16
Cutout appearance doesn't work
973 Views, 15 Replies
09-20-2012 07:03 AM
I have a problem when I want to use a cutout.
My purpose is to get a perforated plate but Inventor doesn't show this.
Only the black color is shown and not the holes.
What am I doing wrong?
Thanks in advance
Nick
I have found a solution. Instead of using the png-file to cut out the black circles, I made those circles transparant and used the image as image. Inventor makes transparant what is transparant in the image
Nick
1,277 Kudos
Post 2 of 16
Re: Cutout appearance doesn't work
09-20-2012 07:09 AM in reply to: nick.jeuris
Make sure the "cut" is selected in the command dialog window.
I can't open your file because I am still on 2012.
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
*Pro
120 Kudos
Post 3 of 16
09-20-2012 07:26 AM in reply to: nick.jeuris
if you're just using that .png file to similate perforated plate, the cut away won't work.
Active Member
1 Kudo
Post 4 of 16
09-20-2012 07:30 AM in reply to: Cadmanto
Hi Cadmanto
I'm not doing an extrude, but I am using the cutout option in the appearance menu.
See the screenshot in attachment.
Nick
Active Member
1 Kudo
Post 5 of 16
09-20-2012 07:32 AM in reply to: ampster
What's wrong with the .png file?
890 Kudos
Post 6 of 16
09-20-2012 07:55 AM in reply to: nick.jeuris
I'm not sure what you did wrong, but after I cleard your overrides and set generic to use your image file it worked fine.
Mike (not Matt) Rattray
1,277 Kudos
Post 7 of 16
09-20-2012 07:59 AM in reply to: nick.jeuris
Sorry I misunderstood your issue.
2 thoughts, first maybe the transparency needs to be adjusted on the png file
and second, can you use this appearance in the color portion of the style and standard editor?
Best Regards,
Scott McFadden
890 Kudos
Post 8 of 16
09-20-2012 08:01 AM in reply to: Cadmanto
You forgot that there are no longer colors in 2013. He has to work with the appearance editor.
2,128 Kudos
Post 9 of 16
09-20-2012 08:06 AM in reply to: Cadmanto
..... Styles and Standards, Materials and Colors questions based on 2012 and earlier releases.
It has all changed in 2013.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
1,277 Kudos
Post 10 of 16
09-20-2012 09:20 AM in reply to: mrattray
Alrighty then...:smileyfrustrated:
I am still on 2012, so I guess I have something to look into.
Thanks for the heads up guys.
Best Regards,
Scott McFadden
