The part was cut using split tool.How could i have the cut start 30mm in from the narrow end (not start at the tip).I could not think of another way to cut other then the split feature
attached .ipt is 2013 but i can view with 2014
Cheers
Harold
You do not need to create a workplane to Split.
You can use a 2D sketch line on the XZ plane.
