I created an assembly as attached. However the part "center rod.ipt" has interference wth four patterned components "support2.ipt". I want to cut 4 v shaped slot at the "center rod.ipt" based on the four patterned components. May I know how shall I do that.
Solved by Curtis_Waguespack. Go to Solution.
Hi lis_wang,
Have a look at this link:
http://inventortrenches.blogspot.com/2011/03/find-interference-and-add-tolerance-to.html
I hope this helps.
Curtis
